VooDoo shift pattern doesn't line up
Old Dec 29, 2005 | 11:37 AM
lydas2000's Avatar
SUCCESS!
I used a couple of small pieces of a plug from a tire repair kit. A little trial and error and I got.
As far as the shift pattern, I think I would prefer not to have it, but this was a trade for another knob, so I didn't mind. Now that it lines up, I think it looks pretty good.
thanks for the suggestion
Old Dec 29, 2005 | 11:43 AM
Rick Hesel's Avatar
Former Sponsor
[QUOTE=lydas2000,Dec 29 2005, 02:22 PM] Just installed an etched pearl finish VooDoo knob. The functionality is great, but the shift pattern is almost completely backwards. Any fixes? Plumbers tape, flange nut, etc.?
Old Dec 29, 2005 | 11:46 AM
r_duff's Avatar
werd!
Old Dec 29, 2005 | 11:48 AM
Saki GT's Avatar
I paid attention!
Old Dec 29, 2005 | 12:07 PM
happs22's Avatar
Originally Posted by Rick Hesel,Dec 29 2005, 03:43 PM
The solution is quite simple, and it has nothing to do whatsover with the locknut, as some posts here have suggested. And forget the aluminum foil and small pieces of cardboard -- they're very inelegant solutions.
Hehe, listen to Rick. . . not me.
Old Dec 29, 2005 | 12:28 PM
lydas2000's Avatar
I don't have ADHD. I traded with another member so I never received any indtructions.
I was hoping you would weigh in Rick since it is your product. My not-so-elegant solution seems to be working, but if it starts to loosen over time, I will try the Loctite.
thanks
Old Dec 29, 2005 | 02:26 PM
Foo Cat's Avatar
You can put four or five layers of white teflon tape (plumbing) on the threads and it will change where the shift pattern lines up. It may take you a couple of times to get the pattern to line up correctly, but the teflon tape is very cheap and the process is easily reversed.
Old Dec 29, 2005 | 05:33 PM
Rick Hesel's Avatar
Former Sponsor
The Loctite is the best solution. A drop or two, and if your remove the knob, another drop or two when it is screwed back down.
Old Dec 29, 2005 | 07:22 PM
lydas2000's Avatar
Just went and got some. Should be set tomorrow. Thanks for the tip!
Old Dec 29, 2005 | 07:28 PM
YZER's Avatar
Well I see you got your knob in. I hope you enjoy it!
zacksbro11
Tampa
18
Feb 10, 2011 01:26 PM
Quick_Silver
Nov 16, 2006 08:15 PM
M@verick
Apr 29, 2004 03:55 AM
Y2K1S2K
Feb 21, 2004 09:00 AM
simons2k
Jul 2, 2003 01:49 PM
