anyone use their voodoo knob with a locknut?
Old Feb 20, 2004 | 07:22 PM
Y2K1S2K's Avatar
Default anyone use their voodoo knob with a locknut?
i kinda like a little higher...but with round knob....but it seems like the threads dont start right where the hole is...
can someone explain this better?
Old Feb 20, 2004 | 07:27 PM
boiler's Avatar
The whole purpose of this knob was to let the knob set lower on the lever which makes the shift lever shorter. This means you have to move the knob less distance to make a shift. I doubt that you will have enough threads in the knob to put a locknut underneath the knob.
If the height of the knob is bothering you I would suggest that you get another knob.
Good luck,
Bob
Old Feb 20, 2004 | 09:22 PM
xviper's Avatar
I suppose you could try one of two things:
1. Put the stock lock nut down as far as it will go and then see if the thread on the stick will reach the thread inside the knob. It might not but if it does, then you may have the knob higher than you'd like.
2. You can consider getting a die (like in tap and die) and extend the threads on the stick so that the stock lock nut will go far enough down for you to have the knob at your desired height.
Old Feb 21, 2004 | 09:00 AM
boiler's Avatar
If all else fails, you might talk to Muz or Rick (Hessel) and see if they have one that would work for you.
01SSM
May 19, 2014 08:38 AM
M@verick
Apr 29, 2004 03:55 AM
simons2k
Jul 2, 2003 01:49 PM
Gators1
Aug 3, 2001 03:16 PM
ricosuave
Mar 14, 2001 08:59 AM
