Vortech warranty
The Vortech High Output Supercharging System will add 108 horsepower @ 8 psig to the S-2000. It features a V-2 SQ SC-Trim supercharger and allows retention of all factory accessories including A/C and power steering. The integrated dual pass air/water Maxflow Power Cooler charge cooler system allows for effective street operation using a closed loop water cooling system with a stand-alone pump, tank and front mounted heat exchanger. All components needed to bolt the system to a stock vehicle, such as mounting plates, fuel pump, supercharger oil feed and drain assemblies, electronic timing controller and compressor bypass valve are included. A three-year limited warranty is provided on the supercharger. Satin or polished finish components are available.
Dubai
Nov 22, 2003 02:14 AM
