VTEC not VTECing
Old Jan 25, 2001 | 12:42 PM
Spectre's Avatar
This has probably been posted b4. I've had 2 consecutive oil changes with Castol Syntec. I've got 8K on the odo. My oil level is perfect. Ok, here is what happens....nothing.
I don't feel any surge or don't hear the change in engine tone like I use to. The car revs smoothly to 9k with no change in feel at the VTEC rpm range. Any ideas or suggestions???????????????????
Thanks
Old Jan 25, 2001 | 12:50 PM
Tox's Avatar
Tox
This is in first gear?
S2WOOOW's Avatar
It's probably not the oil. I've been using Syntec with no problems.
Did it start when you switched to Syntec or just started recently.
Old Jan 25, 2001 | 01:01 PM
ricosuave's Avatar
i've got the same situation. i guess the synthethics work too well and smoothing the engine. i've been using mobile 1 for my oil and the surge seems to have diminished. i wonder if using regular oil would cause the surge to return?
Old Jan 25, 2001 | 01:32 PM
Luder94's Avatar
Pull the meter fuse! This will disallow VTEC to engage...now drive the car. Does it feel any different than before? If you don't get that as quick acceleration from a moving start, then your VTEC was VTECing with the fuse in.
That's the method I've used to diagnose Prelude VTECs. I think it may work with the S2 also.
Old Jan 25, 2001 | 01:35 PM
Hootsama's Avatar
MAP sensor is shot, maybe?
Old Jan 25, 2001 | 03:43 PM
Spectre's Avatar
Thanks for the suggestions. I am going to give them a try.
Need my VTEC fix!
Old Jan 25, 2001 | 03:59 PM
Spectre's Avatar
[QUOTE]Originally posted by Luder94
[B]Pull the meter fuse!
Deliverance
Feb 19, 2010 12:43 PM
Rickjames
Apr 13, 2004 02:10 PM
Iggy_Type_R
Aug 6, 2002 08:59 PM
wilch
24
Jul 12, 2002 04:49 PM
bguernsey
Jan 26, 2001 06:43 AM
