Vtec switchover
Old Apr 18, 2011 | 05:07 AM
  #21
skurge's Avatar
i dont think it needs WOT to engage, i'm pretty sure mine has kicked in at less than WOT, maybe 80% + or so i'd say?
Old Apr 18, 2011 | 06:06 AM
  #22
Saki GT's Avatar
Originally Posted by S~Factor
Originally Posted by Sfedai0' timestamp='1302929579' post='20472411
...though I forgot to mention that this is an AP2. Maybe its just not as noticeable.
Well, there's your answer right there.
AP2 has a slightly different power band - around 20-30 hp is avail before VTEC so you don't feel as big a kick, but you get the power sooner.
Old Apr 18, 2011 | 10:41 AM
  #23
00vsmcoupe's Avatar
Agreed. Oil Pressure is needed for VTEC to engage. When you aren't WOT, you arent building oil pressure as fast, but it eventually will crossover. My old Civic would cross over around 4500rpm at WOT, and around 5500 or so when lighter on the throttle... So I assume it would be the same case for an s2000- just different RPM ranges.
Old Apr 18, 2011 | 01:58 PM
  #24
skylinrcr01's Avatar
Originally Posted by LowFlyin'
Originally Posted by bakalag' timestamp='1302935469' post='20472557
[quote name='thomsbrain' timestamp='1302929934' post='20472421']
VTEC does not engage unless you are at full throttle or near it.
hmm I thought so, nice to learn something new everyday =D
I don't VTEC enough to come up with that conclusion so it was nice to know this tidbit of information
You know you can only VTEC 500 times or so. So, good on you for saving them[!]
[/quote]
After the 500 times, check your VTEC fluid resivor for VTEC fluid discoloration (the dye in the fluid will change from a light blue to a black). Its unsafe to VTEC if your fluid isn't clean, you may throw a valve.
StwoKrocket
Apr 8, 2004 04:20 AM
