water on floor and water on floor!
Old Jan 29, 2001 | 11:43 PM
silverman2's Avatar
I found today that I have water leaking onto the carpet on the passenger side floor. How is this problem fixed or is it due to excessive humidity in the air?
Worse still I found a small coolant leak on the garage floor under the engine... not the dreaded porous block I hope! Done 10k km. Anyone know/remember where the previuos engine water leaks came from; what part of the engine?
Old Jan 30, 2001 | 12:00 AM
cthree's Avatar
Administrator
The water in the passenger footwell is from the AC. Check for a hose there. Sometimes the passenger can kick it. The water on the garage floor might be the same problem. Is it green? If not, it's just water from the AC condenser (humidity).
Old Jan 30, 2001 | 01:33 AM
silverman2's Avatar
thanks for the reply cthree. the water on the garage floor is coolant - that is why I am worried... a/c leak on carpet is bearable.
Old Jan 30, 2001 | 03:31 AM
cdelena's Avatar
Under normal conditions it should leak zero coolant.. you do have a problem.
Old Feb 1, 2001 | 07:55 PM
dlq04's Avatar
Honda has issued a Technical Service Bulletin on this subject. It applies to both 2000 and 2001 cars. If your using the air conditioning during high humidity the fan can push excess moisture into the heater box and it will drip in the passenger side. It's a simple repair at the dealership. Since we still have snow here in MI, I didn't qualify for a repair yet! But it sounds like you might. It's free.
Old Feb 2, 2001 | 04:08 PM
Utah S2K's Avatar
And just what TSB number would that be?
Old Feb 3, 2001 | 03:00 AM
MJMSC's Avatar
I've got this problem, but I had it worked on last fall, then the cool weather hit....so it's probably still there...please post TSB.
Old Feb 3, 2001 | 04:02 AM
dlq04's Avatar
If you can't ask any nicer than that, look it up yourself.
Old Feb 3, 2001 | 05:18 AM
cdelena's Avatar
Yep, that's the spirit of the board! Why don't you take the TSB and shove it. Ask a few questions dlq04, we will fall all over ourselves to help you out.
[Edited by cdelena on 02-03-2001 at 06:21 AM]
Old Feb 3, 2001 | 07:28 AM
Sunchild's Avatar
Pretty please with sugar on top?
Top_down
Aug 9, 2014 11:34 PM
s2klariat
Dec 1, 2011 02:22 PM
bboixtc
Oct 30, 2009 06:43 AM
timlee2002
Jul 25, 2009 03:10 PM
flag2carrot
Jan 8, 2008 09:24 AM
