Water shield for CAI?
Old Jul 23, 2004 | 03:35 PM
SilverKnight's Avatar
Default Water shield for CAI?
Is this the shield which can prevent hydrolock with a CAI? http://cgi.ebay.com/ebaymotors/ws/eBayISAP...&category=38634
Old Jul 23, 2004 | 03:40 PM
xmugens2kx's Avatar
you need bypass valve for CAI not a heat shield
Old Jul 23, 2004 | 03:41 PM
bypass valve negates the performance aspect of the CAI is what I've been reading from some posts on here?
Old Jul 23, 2004 | 05:14 PM
terd ferguson's Avatar
What I think most CAI users are most concerned about is water dripping onto the filter from the drain hole, not running through puddles. That heat shield would prevent water from dripping onto the filter (and soaking through and eventually being sucked into the engine if there was enough water in the tube). There are a couple of drain holes on each side of a water channel under where the edge of the hood would be when its shut. The one closest to the front of the car on the passenger's side is the culprit. If you look straight down that hole, you can see your filter. With a good, heavy downpour water may drip onto the filter, eventually soaking through and puddling up in the intake tube.
I have devised a cheaper and easier solution. It weighs less as well. I put a piece of black electrical tape over that hole. Its been there for 2 months now and my filter has stayed bone dry even when sitting in the heaviest of downpours. That's what I would suggest to all who may be concerned about this type of hydrolock problem. To those concerned about the other type of hydrolock (running through deep puddles), I would suggest you not run through deep puddles and you should probably be ok.
Old Jul 23, 2004 | 05:52 PM
dispader's Avatar
Old Jul 23, 2004 | 07:20 PM
w1ngman's Avatar
[Oh...and the tape is a GREAT idea! ]
Old Jul 24, 2004 | 03:05 PM
does anyone have pics of the hood holes? I'll be sure put tape on them if I get a CAI.
Old Jul 24, 2004 | 04:49 PM
S2K TX's Avatar
yes it does... but at least you know your engine is safer.... and plus couple of ponies is not a big deal
Old Jul 24, 2004 | 04:56 PM
apex2k's Avatar
https://www.s2ki.com/forums/index.php?showt...229&hl=umbrella
Old Jul 24, 2004 | 05:49 PM
You don't need a bypass valve unless you are going to be driving through bodies of water. In that case, you need a snorkel extention, a la the humvee or jeep.
