WEEEEEEEEEEEEEEEEEEEee
Old Sep 28, 2007 | 12:23 PM
Rdizzle's Avatar
Originally Posted by CA_S2K,Sep 27 2007, 09:15 PM
I was talking to a buddy and i know this sounds kinda wierd but he a spring compreesor is unnecessary, is it possible without the tool? THANKS!
Actually, your buddy's right--you don't need a spring compressor. The ghetto way to do it is to wrap a blanket in between the coils of the spring and tightly around the spring itself. When you unbolt the top nut, the spring will "pop" a little (maybe about an inch) and you can take it off that way. How do I know? Well, I've done it before.
Also, since you're installing lowering springs, they will be shorter than stock so you shouldn't need a spring compressor to install them back onto your stock shocks.
HOWEVER, I do want to stress that this method is not recommended and can be dangerous!! Autozone rents those spring compressors for free (w/ deposit) so go get one of those...much safer.
Old Sep 28, 2007 | 05:25 PM
CA_S2K's Avatar
Sweet thats what he said to do, thanks for the info
Old Sep 28, 2007 | 05:32 PM
way2low01's Avatar
spring compressor is not needed for the s.
Old Sep 28, 2007 | 10:41 PM
callaesthetics's Avatar
i didn't use a spring compressor. I used my own body weight to push down on the shock. There's very little pop, nothing violent.
Old Sep 28, 2007 | 10:46 PM
HondaS's Avatar
YOU DO NOT NEED SPRING COMPRESSORS, i did it my self with out them
all you need is a towl a 2x4 a allen key and a 14 mill wrench
Old Sep 28, 2007 | 11:19 PM
CA_S2K's Avatar
SOOO this is ALL i need no more no less? wow i cant wait to start! gotta work on sat though
Old Sep 29, 2007 | 02:16 PM
CA_S2K's Avatar
i got the shocks out but having alot of trouble taking it apart, too tight! if the oem shock spins while im trying to loosen it, is that bad?
Old Sep 29, 2007 | 03:28 PM
CA_S2K's Avatar
i got these tanbe gf210 and where is says 0607 ap1GR is that the rear and ap1GF is the front? because i just installed the front springs and its higher, only when you measure it, you cant really see it, did i do someting wrong thanks
kikkomon
Jan 7, 2012 10:44 AM
guedo
Aug 10, 2009 01:00 PM
rSx KinGz-!
Sep 4, 2007 02:30 PM
sss2k921
Jan 4, 2005 02:03 PM
sss2k921
Dec 17, 2004 12:19 AM
