Weight Distribution
Old Mar 26, 2005 | 12:34 PM
jdnissanz's Avatar
Arrow Weight Distribution
I thought the Honda S2000 had 50/50 weight distribution and that is why it was amazing at handling, but went on honda.com and found out my 05' was 49/51 weight distribution and I was wondering if they just changed that for the 04' 05' models or was this how it always was? BTW...Anyone know the reason to why the car is now a different weight distribution if it did really change...Thanks in advance for all the info that will be provided.
Old Mar 26, 2005 | 12:40 PM
YellowS2kPwr's Avatar
Pre 04's were 50/50, no idea why they changed it.
Old Mar 26, 2005 | 12:52 PM
jdnissanz's Avatar
DIMENSIONS: BODY/SUSPENSION/CHASSIS
TRIM LEVEL
Starting MSRP
S2000
$33,150
High X-Bone Monocoque Frame Standard
Independent In-Wheel Double Wishbone Suspension with Coil Springs Standard
Stabilizer Bar (mm, front/rear) 26.5 / 25.4
Electric Power-Assisted Rack-and-Pinion Steering (EPS) Standard
Steering Wheel Turns, Lock-to-Lock 2.6
Steering Ratio 14.9
Turning Diameter, Curb-to-Curb (ft.) 35.4
Power-Assisted Ventilated Front Disc/Solid Rear Disc Brakes (in., front/rear) 11.8 / 11.1
Alloy Wheels (in., front/rear) 17x7.0 / 17x8.5
Bridgestone Potenza RE050 Tires (front/rear) P215/45 R17 87W / P245/40 R17 91W
DIMENSIONS: INTERIOR MEASUREMENTS
TRIM LEVEL
Starting MSRP
S2000
$33,150
Headroom (in.) 34.6
Legroom (in.) 44.3
Shoulder Room (in.) 50.7
Hip Room (in.) 49.8
Cargo Volume (cu. ft.) 5.0
Passenger Volume (cu. ft.) 44.8
Seating Capacity 2
DIMENSIONS: EXTERIOR MEASUREMENTS
TRIM LEVEL
Starting MSRP
S2000
$33,150
Wheelbase (in.) 94.5
Length (in.) 162.2
Height (in.) 50.0
Width (in.) 68.9
Track (in., front/rear) 57.9 / 59.4
Curb Weight (lbs.) 2835
Weight Distribution (%, front/rear) 49 / 51
Old Mar 26, 2005 | 02:10 PM
Warren J. Dew's Avatar
I can think of a couple of changes that would have switched weight to the rear:
- the larger wheels and tires probably added more weight to the rear than the front, since the rear wheels are wider.
- the larger displacement shortened the piston rods, which may have reduced the front weight.
If they beefed up the differential, that would have increased the weight in the rear, too.
Old Mar 26, 2005 | 03:03 PM
Fongu's Avatar
OK, lets get practical. We're talking 1% change. That's what, 28 lbs. That's margin of error. That's less than 1/2 a tank of gas. Can you seriously feel the handling difference in from full tank to 2/3's full. Very few will be able to tell, fewer will be a good enough driver be effected by it.
Old Mar 26, 2005 | 04:01 PM
oknessad's Avatar
Fongu I was just going to say that.... Gas alone changes the distribution a few percentage points at every fill up.
Old Mar 26, 2005 | 04:22 PM
Stratocaster's Avatar
Hey, Hold on just one Minute!
It has always been 49/51!
2001 49/15 http://www.hondanews.com/CatID2071?mid=200...c&archives=2001
2002 49/51 http://www.hondanews.com/CatID2036?mid=200...c&archives=2002
2003 49/51 http://www.hondanews.com/CatID2071?mid=200...c&archives=2003
2004 49/51 http://www.hondanews.com/CatID2071?mid=200...c&archives=2004
2005 49/51 http://www.hondanews.com/CatID2071?mid=200...c&archives=2005
All of the above links are to Honda's own news site.
Now that the cat is out of the bag, there is very little differance in the car as a whole from year to year. Yes they have changed some of the bolt on parts, but the car as a whole is the same.
Old Mar 26, 2005 | 04:26 PM
PdC's Avatar
PdC
Nah! The 04-05s are much better!
Old Mar 26, 2005 | 07:06 PM
ayS's Avatar
ayS
it's always been 49/51.
Old Mar 26, 2005 | 07:23 PM
xviper's Avatar
We just say "50/50" for ease of conversation. Good Lord, why would anyone blow a nut over 1%. I can change wt. dist. of the car if I ate a super large pepperoni pizza by myself. And I can change it back after I take a big dump.
