What all is needed with VAFC-II?
Originally Posted by deathsled,Dec 28 2006, 06:47 PM
and you dont think that stuff is compensated for by using input from the pressure and intake temp sensors?
What is it good for one asks. Ultimately the VAFC can correct fuel trims for mods that effect AFR getting them to back to 0 . Fuel trims floating around 0 means the ecu is happy . It is just as it claims , a fuel controller . You can use it to scale different injectors and to correct fuel trims nothing more.
But trying to lean out the car to make more power will effect fuel trim and the ECU will compensate for it . Plus it is not good for the engine . I see poeple saying they got back from the dyno and gain 10hp but there AFR is 13.9 at WOT
This is not the way to make power . Plus now you are prone to knock and the ECU will just pull timing anyway . A one gear pull at WOT on the Dyno is not the same as rowing 5 gears at WOT on the highway . So whats the difference with other ECU's
The way the Amuse , Mugen , AEM makes power as they dont need to comply with US regulations and they change the ECU target AFR to anything they like and can control timing . But only the AEM is user adjustable and can compensate for different mods . The pre programed race ecus were tuned most likely with the manufactures specific mods
The way the Greddy Ultimate works, is it post processes everything so the ECU is not being trick at all .Just satisfy the fuel trims and start tuning . You still cant tune for PT throttle AFR'r as the factory ECU is still trying to keep things at 14.7 . but you can change timing to make it have snappier throttle response .
To be able to tune the Vafc or the Greddy or any piggyback properly you will NEED and OBD2 scan tool that can read fuel trim .This is not the same as reading the AFR's with a wide band.
^^^^good info. but remeber too that all engines are a little different. my vafc is set to 13.8-13.9@WOT and my car doesnt knock, ping or any of the usual detonation type of symptons. i would have never set it that way, but through HOURS of dyno tuning we deduced that the car is perfectly safe where its safe. i would NEVER recomend anyone else to shoot for such a lean AFR, it just works for me.
i wish you where near me twizted, i want emange in the worse way, and for you to tune it! your always a vault of info twizted
One of the main reasons I want to tune my VAFC 2 is to lean it out a bit..It will be nice to add a little power, but I don't like having to wash my car every other day because of the black shit on the back of my car...I also had the VAFC 2 on my Si and it made some nice numbers, but I had head/Valve work and other mods...We'll see how it goes
But trying to lean out the car to make more power will effect fuel trim and the ECU will compensate for it . Plus it is not good for the engine . I see poeple saying they got back from the dyno and gain 10hp but there AFR is 13.9 at WOT eek2.gif This is not the way to make power . Plus now you are prone to knock and the ECU will just pull timing anyway . A one gear pull at WOT on the Dyno is not the same as rowing 5 gears at WOT on the highway
Its true that the fuel trims can ultimately have some affect on fuel at WOT, but those fuel trims are adjusted during closed loop operation at part throttle, and once they have learned your car your WOT AFR isn't going to vary much.
If I lean my car out to a 15.0:1 AFR under WOT then its going to pretty much stay there, fuel trims aren't going to bring that down into the low 13s.........
I'm getting ready to install my VAFC as well with the boomslang harness, but where the heck is the ECU? It seems like this thread has gotten off the topic of how this guy wants help on installing his VAFC and on the topic of talking 5h1t. just help the guy out.... and me too :-)
Originally Posted by Riley2638,Dec 28 2006, 06:46 AM
I'm bringing this thread back to let everyone know that I'll be tuning my VAFC 2 on the 12 of Jan.... I will post my results after the first tune..I'm also planning on taking it back to dyno again 2-3 weeks later to see if the ECU actually "re-learns" the base maps...Hopefully this will put to rest all the speculations and rumors associated with this particular topic...By bringing this topic back to life, I really don't want anyone arguing over if it works or not...Let's just wait on my results...
Not yet...My tuner postponed my tune until next month..I'm still at school anyways, so i wouldn't have been able to go home when the first tune was scheduled anyways...I'll let you guys know when I'm able to tune it..
mustangkiller01
Jun 12, 2004 07:20 AM
