what is power shifting?
Old Sep 27, 2001 | 11:13 PM
seung's Avatar
Default what is power shifting?
Old Sep 27, 2001 | 11:23 PM
4IGS2000's Avatar
Spammer
shifting while the gas pedal is fully depressed
Old Sep 28, 2001 | 07:11 AM
The Raptor's Avatar
Active Streak: 30 Days
Full throttle power shifting is pretty hard on a car -- but a gas. I destroyed both the clutch and the tranny in my 93 Prelude VTEC doing that. The clutch was just about the ugliest thing I've ever seen. Don't do dat no more!
Old Sep 28, 2001 | 07:21 AM
Moleman's Avatar
Also known as "speed shifting".
Old Sep 28, 2001 | 07:44 AM
DaRKCrow's Avatar
Its forcing your clutch to catch while on a full throttle. The purpose is try to keep the RPM higher once getting into the higher gear. Also can gain a pull but.....DONT DO IT! Forcing a catch at 9k RPM is not highly recommanded.....
DaRKCrow
Old Sep 28, 2001 | 11:33 AM
Wesmaster's Avatar
I always thought "speed shifting" was shifting while the gas is still in, but not necessarily at full throttle. If I shift at 9,000 RPM and keep the gas full throttle I'll redline immediately. Am I missing something?
Sometimes (rarely) I speed shift and just let off the gas about half way, instead of coming all the way off.
Note: I personally don't speed shift while racing, just when I'm very lazy.
Old Sep 28, 2001 | 11:43 AM
Cyber Logic's Avatar
[QUOTE]Originally posted by Wesmaster
[B]I always thought "speed shifting" was shifting while the gas is still in, but not necessarily at full throttle.
Old Sep 28, 2001 | 12:14 PM
JT-KGY's Avatar
[QUOTE]Originally posted by Cyber Logic
[B]
This is what I do...call it what you want but, I usually load the shifter and then when I hit 9000 I let off the gas to between 1/4 and 1/3 throttle while I'm pushing in the clutch then as I'm letting out the clutch a split second later I mash the gas again...I find that the usualy method of shifting normally (letting off the gas all the way and putting in the clutch and then shifting releasing the clutch and then mashing the gas seems to put to much stress on the drivetran...I realize that my method prolly is pretty hard on the clutch but, it is the fastest way for me to shift the S2k and you don't get the split second of lag and thud you get when shifting normally.
solitarycheese
Jul 11, 2014 06:03 PM
megathunder
Mar 14, 2009 03:15 PM
emrillive
Oct 9, 2004 06:12 PM
FormerH22a4
May 26, 2002 05:52 AM
