When driving aggressively
Old Feb 27, 2005 | 11:23 AM
B.C.'s Avatar
Originally Posted by ayS,Feb 27 2005, 12:16 PM
just wanted to point out no vtecing when cold!
I was just PICKING on you
Old Feb 27, 2005 | 01:20 PM
lilbizzyazn's Avatar
common he got a pre04 haha like most of us
Old Feb 27, 2005 | 02:14 PM
TrueDrezzer's Avatar
The car was made to do so. There is an S2000-only cup at the N
Old Feb 27, 2005 | 02:23 PM
Caffeinated21's Avatar
[QUOTE=TrueDrezzer,Feb 27 2005, 03:14 PM] The car was made to do so. There is an S2000-only cup at the N
Old Feb 27, 2005 | 02:36 PM
YellowS2kPwr's Avatar
There is no event where you will need to stay in VTEC for more than the time that you need to accelerate... why would u even wanna stay over 5k rpm in any gear and drive like that? Of course the engine is going to wear... don't u get tired faster when you're running instead of walking? Don't be lazy, downshift when you need to and stay in 5th-6th on the highway.
Old Feb 27, 2005 | 02:46 PM
tenblade2001's Avatar
I guess you've never Auto-x'd the car nor taken it on a twisty road for an aggressive drive. If you had, you're not in vtec for a majority of the time, then you are not driving the car correectly. The doesn't even begin to make power till vtec....that's how you accelerate out of the turn. Again, if you have good oil running in your engine, then you don't need to worry about parts wearing down.
Old Feb 27, 2005 | 03:08 PM
Nope never autoxed, no twisty roads in Chicago... but what I mostly meant is for normal driving...
Whatever you do, don't vtec in the rain!
Old Feb 27, 2005 | 03:31 PM
RACER's Avatar
I rev past 6k quite often. The majority of the time, I use high revs for a brief amount of time. There is no point in holding 5,500-6,000 revs or more in third gear when I could be at around 4,500 or so revs. There are times that I do not want to be at the higher revs in a 45-55 mph corner because I am putting down sufficient power to the ground. Sometimes being in too low of a gear will put too much power down increasing the chance of the tires breaking adhesion.
A racetrack is a whole other ballgame. From the time I begin to accelerate off of a corner, until the time I am braking at the end of the straightaway, I am at, or above 6k rpm's all the time. There may be a scenario where I am at maximum speed for a given corner and also close to max engine revs. I really don't want to lift off the throttle and select the next highest gear for fear of upsetting the balance of the car until it is straightened out enough to do so. This could mean holding the revs at around 9,000 rpm's. The only other time I would hold max engine revs for any length of time, is if I was maxed out in 5th gear going 140 mph.
On a road other than a racetrack, depending on the layout of the road, I would never hold high rpms as I find no benefit in doing so. Keep in mind, there is no stop watch from point A to point B on a twisty public road.
I am not into putting excess wear on my engine to gain 2/10's of a second that I will not even know about I'd rather just throw her into 4th gear
Old Feb 27, 2005 | 10:38 PM
shaolin's Avatar
why drive like grandma when driving a sports car like S?
Old Feb 28, 2005 | 12:14 AM
RACER's Avatar
sharky89
Feb 7, 2012 04:45 AM
ONEQUIKSTI
May 30, 2006 10:27 AM
Dragon Curve
Oct 15, 2004 04:39 AM
rastamansar
Nov 29, 2003 07:27 PM
joecro
Jan 15, 2001 03:59 AM
