Why does high RPM matter?
Originally Posted by Wisconsin S2k,Feb 27 2006, 04:45 PM
again, peak torque means absolutely nothing. if the car is still making decent power and more power with gearing than the next upshift, then it's useful power.
it's not a novelty, as it directly contributes to the acceleration of the car.
Peak torque and peak HP DO mean something. The fact that the S2000's gearing is designed to keep you in VTEC after shifting if you go past the peak HP is what saves you. If your gearing allowed you to stay in VTEC and shift at peak HP the 700RPM from 8,300 to 9,000 would do you no good. They muscle car guys have known this for years. Their gearing allows them to shift at max HP and stay in their power band. They don't rev to redline on every shift.
You of ALL people should understand how gearing affects acceleration.
Originally Posted by Wisconsin S2k,Feb 27 2006, 04:10 PM
take the same scenario, but drop the redline of the S2000 by 1000rpm. now the C5 will beat the S2000 even more than before.
so how is the extra 1000rpm not an advantage vs not having the extra 1000rpm? it is part of the reason the car is as fast as it is, regardless of what it's racing against.
Just for giggles, shift the S at 9k and short shift the Z06 by 1k RPM and I'll still bet on the Z06.
Originally Posted by Dylan Hunt,Feb 27 2006, 06:01 PM
Lets say your opponent has a redline of 7k and you have a redline of 9k. When your on the track and your about to hit a corner it would be useless to upshift just for that fraction of a second just to downshift to take the turn again and with 2k more you would have an advantage over the guy with 7k
you are talking only in relation with engine speed, but it is also important the axle ratio, a corvette would rev up to 7000 but if thier final gear is lower maybe it has to shift at the same time as a 9000 rpm S2000. let do an example with the S2000
the stock F20C
a F25C, stroker kit, revving only to 7000 and axle ratio 3.3
both shift a the same time, we just have to know if the extra HP is enough to compensate the lower axle ratio
Juan
Things are different for the muscle car guys because older domestic engines' torque tended to drop off a lot at the high end. (This isn't much true these days anymore, by the way.) For them, the acceleration at redline was actually lesser than the aceleration in the next higher gear.
[QUOTE=ruexp67,Feb 27 2006, 04:08 PM] I am not saying the S2000 does not take advantage of the 9,000RPM redline, just saying that just because it revs to the magic 9,000RPM doesn't make it fast.
Originally Posted by ruexp67,Feb 27 2006, 04:09 PM
Yeah, but then you are not using the cars max potential. That was my point.
Originally Posted by Wisconsin S2k,Feb 27 2006, 10:52 PM
hehe, pete i never said that 9000rpm alone makes it fast. i said its one of the major contributing factors.
A motor that makes 240 HP but only revs to 5,000RPM fitted to the S2000 would (Assuming a similar torque curve) get the car down the 1/4mi in the same time, and at the same speed as the F20C.
There are lots of ways to make power, and high revs are one of them. However, the other ways to make power are also quite valid and would have worked just fine on an S2000.
Originally Posted by Elistan,Feb 27 2006, 10:29 PM
No, that's not quite correct. It doesn't have to do with the VTEC point.
