Will seat removal trigger CEL or AIRBAG lights?
Old Dec 14, 2010 | 02:10 PM
s2cho's Avatar
if you have any problems try this
http://www.honda-acura.net/forums/do-it-yo...-srs-reset.html
Old Dec 14, 2010 | 02:40 PM
mse678's Avatar
Originally Posted by Robert O,Dec 14 2010, 02:56 PM
The drivers side will be fine.I know this because mine is currently out to get one of the center leather panels replaced. Two leads you'll need to disconnect under the seat once you've removed the bolts.I've started the car several times since removal and the airbag symbol light is on ,but I believe it is just indicating because the leads are disconnected.
Now the passenger side I'm not certain on. Performed a search sometime back and was led to believe that if you disconnected the battery before hand there would be no problem. Just not sure and didn't persue it any further because I have no reason to remove mine at ths time.
How is this 'fine' when you have proven that the light will come on after the removal of the seat?
Old Dec 14, 2010 | 03:13 PM
Robert O's Avatar
Because the light is indicating that the air bag is disabled. Same as it would if the harness had parted or had a faulty connection that I didn't disconnect knowingly.Otherwise the system would have no failsafe.
Old Dec 14, 2010 | 03:17 PM
mse678's Avatar
so you have just confirmed that the light will come on after the removal, but we dont know if the light will go away after you put the seat back in..
Old Dec 14, 2010 | 03:53 PM
Robert O's Avatar
Yes we do. Cause I just put it back in and the light is off.With engine running. That'll be thirty bucks please.
Old Dec 14, 2010 | 09:03 PM
mse678's Avatar
I removed the front passenger seat without having to remove any sensors or wiring, 4 bolts and it came right off
anyway check this out
https://www.s2ki.com/forums/index.ph...f=252&t=835338
Old Dec 15, 2010 | 05:42 AM
Reckon's Avatar
No issues on my 05 when I removed both seats to put the Clazzio covers on.
Old Dec 15, 2010 | 06:45 AM
Robert O's Avatar
Is there a rear passenger seat in your S or just a front? Oh.. and your welcome.
Old Dec 15, 2010 | 09:54 AM
rjohnstonstl's Avatar
Did this on my 05' when I detailed it over the summer and had no problems at all. Just be careful not to scratch stuff when lifting the seats out.
Old Dec 15, 2010 | 03:16 PM
FluKy15's Avatar
On my 2007 I took out both seats just fine. I was even able to drive it. As soon as I put the seats back in, it was normal. Just as the above mentioned, the light when on for the passenger seat because of the airbag sensor. Turned off when it was plugged back in.
Iron Buckeye
Sep 4, 2014 05:17 AM
gizzard
Jan 1, 2013 09:10 AM
Kiteland
Car Talk - Non S2000
Dec 23, 2008 07:46 AM
crxrex
Jun 25, 2007 01:30 PM
BrandonS
Oct 17, 2004 11:01 PM
