Windshield sprayer inoperable (drivers side)
Old Dec 4, 2015 | 07:27 AM
Krazykoreankid's Avatar
Default Windshield sprayer inoperable (drivers side)
This is a stock, PAINTED, sprayer nozzle.
Is there a safe procedure to unclog the sprayer without damaging the paint.
How about any tips to clean out the hoses?
Thanks in advance!
Old Dec 4, 2015 | 08:38 AM
Saki GT's Avatar
First, see if the hose is connected, and clear. Just disconnect it and see if it gushes when you activate the sprayers.
If the hose is fine, you might start with a toothpick and see if the nozzle is clogged with crud.
If that doesn't work, try compressed air.
Old Dec 4, 2015 | 10:44 AM
Thanks! i'll try that!
Old Dec 4, 2015 | 01:31 PM
MikeekiM's Avatar
Weird...I have the same issue... Bought the car that way...
Driver's side nozzle is clogged...passenger's side nozzle is fine...
I haven't taken it all apart to try and isolate the problem...mostly because it is not my daily driver, and the car never sees rain, and is never dirty enough that I need to use the windshield wiper fluid... I should root cause it at some point though...
Old Dec 4, 2015 | 01:37 PM
NDAZONE's Avatar
A needle works well. In the past I clogged them while waxing the car.
Old Dec 4, 2015 | 09:22 PM
Ooo I will have to get a needle. Hope I don't have to disassemble too many hoses to find the clog.
Old Dec 4, 2015 | 09:24 PM
Originally Posted by MikeekiM
Originally Posted by Krazykoreankid' timestamp='1449258295' post='23819870
[quote name='Saki GT' timestamp='1449250681' post='23819751']
[/quote]
Strange coincidence, I'll try clearing out the clog with a needle like previously mentioned. See if that gets me any results.
Old Dec 5, 2015 | 06:20 AM
jetboater's Avatar
Once you get it unclogged, you can also use the needle to "reaim" where the spray hits on the windshield if you need to. Just stick the needle into the sprayer hole and move it where you want it
Old Dec 5, 2015 | 12:49 PM
MikeekiM's Avatar
Originally Posted by MikeekiM' timestamp='1449268293' post='23820015
[quote name='Krazykoreankid' timestamp='1449258295' post='23819870']
[/quote]
[/quote]
Definitely going to give that a try!
Old Dec 6, 2015 | 11:38 AM
Saki GT's Avatar
Actually, I'm not even sure if mine work... I still have the factory fill and I can't think I've ever used my washers...
