Windshield sprayer inoperable (drivers side)
Old Jan 2, 2016 | 07:07 AM
  #21
davidc1's Avatar
Originally Posted by Saki GT
Actually, I'm not even sure if mine work... I still have the factory fill and I can't think I've ever used my washers...
I've heard this before, especially from my mechanic and friends with their modified car. They actually remove the whole system.
I just can't even imagine that! It's not like I use the washers everyday.....but it is super annoying when you're windshield gets dirty, but you can't wash your car yet.
Or, what the heck do you do when, say, you're driving just after it's rained, the roads are wet, and cars are kicking up spray. It just totally coats your windshield.
Old Jan 2, 2016 | 07:10 AM
  #22
davidc1's Avatar
Originally Posted by Krazykoreankid
Does anybody know how to dissolve calcium build up without damaging paint?
Using LimeAway, or TSP works, but would damage paint. You can try vinegar.
Old Jan 2, 2016 | 07:11 AM
  #23
davidc1's Avatar
Originally Posted by Spagolli94
Originally Posted by MikeekiM' timestamp='1449268293' post='23820015
[quote name='Krazykoreankid' timestamp='1449258295' post='23819870']
[quote name='Saki GT' timestamp='1449250681' post='23819751']
First, see if the hose is connected, and clear. Just disconnect it and see if it gushes when you activate the sprayers.
If the hose is fine, you might start with a toothpick and see if the nozzle is clogged with crud.
If that doesn't work, try compressed air.
Thanks! i'll try that!
Weird...I have the same issue... Bought the car that way...
Driver's side nozzle is clogged...passenger's side nozzle is fine...
I haven't taken it all apart to try and isolate the problem...mostly because it is not my daily driver, and the car never sees rain, and is never dirty enough that I need to use the windshield wiper fluid... I should root cause it at some point though...
[/quote]
How strange - I had the exact same issue. Driver's side only and I also bought the car that way. Is this a common problem?
Last time I had the car in for an inspection, the mechanic unclogged it for no charge, so it must have been an easy fix.
[/quote]
Happens al the time to all kinds of cars.
Old Jan 2, 2016 | 03:08 PM
  #24
MikeekiM's Avatar
Ah...that reminds me...I have a bottle of CLR that should do the trick!
http://www.amazon.com/Calcium-Lime-a...1&keywords=clr
Old Jan 11, 2016 | 01:28 PM
  #25
imnida's Avatar
Holy god.. Going on 9 years of ownership and that has been a problem all nine years. Thinking it might be time to quit being lazy about that lol
Old Jan 12, 2016 | 09:59 AM
  #26
hirev's Avatar
Just to add a contrast, i just the washers regularly and use fluid I buy by the gallon at auto parts stores...NEVER had a problem in 12 years. Go figure?
Old Jun 27, 2016 | 10:32 AM
  #27
Krazykoreankid's Avatar
sad news. after fiddling with one of the sprayers, the other one has now stopped working... how does that even happen?
dirtykoala
Apr 21, 2011 09:38 PM
danx
Nov 10, 2008 04:38 PM
Avionics86
Nov 28, 2006 07:48 PM
Cossa
Apr 30, 2004 06:26 AM
tims2k
171
Jan 8, 2004 01:17 PM
