Windshield squirters
Old Jan 14, 2009 | 10:27 AM
azess2kay's Avatar
Default Windshield squirters
Bought a Seibon hood and had it painted. Body shop told me to bring in old hood for exact paint match. I asked the body shop to take squirters out of old hood and put in new hood. They took squirters out off old hood. When I went to pick up new hood and old hood they handed me the squirters. They said "one has a green dot and one has a blue dot and we don't know which side is which". Does it matter? I would think the dots are there for a reason. Any help you can give will be appreciated. Thanks in advance.
Old Jan 14, 2009 | 11:42 AM
tbtak's Avatar
IMO it should not matter on my Seibon hood mine are only for looks anyway...
Old Jan 14, 2009 | 12:04 PM
EVAN&MONICA's Avatar
It shouldnt matter but check the length of the squirter hoses one may only be able to reach one squirter hole so that would make it easy but if all else fails trial and error couldnt hurt good luck
Old Jan 14, 2009 | 03:25 PM
millertown15's Avatar
They should be the same. Stick em on there!
Old Jan 14, 2009 | 08:23 PM
JadeRaven's Avatar
They dumb.
Old Jan 15, 2009 | 02:38 AM
mrxwormxsayz's Avatar
For the MG Style Hood are there even holes for the water squirter things?
Old Jan 15, 2009 | 05:03 AM
azess2kay's Avatar
Yes, there are holes for the squirters. There are, however, no holes for the plastic clips that hold the squirter hoses.
For the record, I tried the squirters in both holes - both worked fine. Apparently Honda put the 2 different colored dots on the squirters just to confuse old farts like me.
Also for the record, prior to painting, it took 2 days bodywork to fill the pin holes and low spots in the Seibon hood but the hood fit perfect.
Old Jan 15, 2009 | 06:06 AM
SheDrivesIt's Avatar
The left and right nozzle do have different part numbers. http://www.hondaautomotiveparts.com/auto/j...WASHER+%28KA%29 It probably has something to do with angle or spray pattern. Shouldn't really matter. They should be easy enough to swap.
nightcrawler7188
Feb 25, 2008 10:00 AM
nightcrawler7188
Nov 21, 2007 01:52 PM
Marco
Mar 26, 2006 07:50 AM
Red_Ohio_Rocket
Aug 20, 2004 06:28 AM
Red_Ohio_Rocket
Jul 25, 2004 05:26 AM
