Wolo Air Horn Install Problem
I wired up my horn compressor exactly like it says to do in this link.
http://www.wolo-mfg.com/400%20english.pdf
The horn compressor gets no juice when hooked up like the diagram using the relay. I hooked the compressor up to the horn wire and ground to test it and it works fine.
Any ideas why this won
Originally Posted by Stratocaster,Jan 24 2007, 12:14 PM
86 should be to ground. With 86 to 12+ AND 30 to 12+, the relay will never engage. Also I assume that 85 is connected to the wire that is connected to the OEM horn. That is 12+ when the horn botton is pressed.
Ground 86 and leave everything else the way it is in the pic?
