Wolo Air Horn Install Problem
Old Jan 18, 2007 | 11:36 PM
WTFWASTHAT?'s Avatar
Default Wolo Air Horn Install Problem
I wired up my horn compressor exactly like it says to do in this link.
http://www.wolo-mfg.com/400%20english.pdf
The horn compressor gets no juice when hooked up like the diagram using the relay. I hooked the compressor up to the horn wire and ground to test it and it works fine.
Any ideas why this won
Old Jan 19, 2007 | 01:09 PM
steven975's Avatar
relay could be defective.
Old Jan 24, 2007 | 11:01 AM
Anyone???
I don
Old Jan 24, 2007 | 11:04 AM
Stratocaster's Avatar
Here is how they should be installed. So if you are not getting the voltage to the compressor, then there is a wiring error to in the relay.
Old Jan 24, 2007 | 11:09 AM
Thanks for your reply! My relay looks alittle diff. Can you please look over the diagram that came with mine?
Thanks!!!
Old Jan 24, 2007 | 11:14 AM
86 should be to ground. With 86 to 12+ AND 30 to 12+, the relay will never engage. Also I assume that 85 is connected to the wire that is connected to the OEM horn. That is 12+ when the horn botton is pressed.
Old Jan 24, 2007 | 11:16 AM
You rule! I will try it out in alittle bit and report back. Thanks!
Old Jan 24, 2007 | 11:19 AM
Thanks. let me know. I wrote that diagram for times such as these
Old Jan 24, 2007 | 11:25 AM
TurboDSMJ's Avatar
Haha I just cut some 16 gauge wire, ran it to the wire for the stock horn, and mounted everything up. 120 decibles, no relay's or fuses. I love Pep Boy's.
Old Jan 24, 2007 | 11:26 AM
Sorry...So just to be clear.
Ground 86 and leave everything else the way it is in the pic?
