Wolo Air Horn Install Problem
Old Jan 24, 2007 | 11:27 AM
Stratocaster's Avatar
Originally Posted by TurboDSMJ,Jan 24 2007, 02:25 PM
Haha I just cut some 16 gauge wire, ran it to the wire for the stock horn, and mounted everything up. 120 decibles, no relay's or fuses. I love Pep Boy's.
That may be a problem. The horn and brake lights are on the same curcit. So hitting the horn and brakes at the same time will blow the fuse and you lose both the horn and brake lights. Fair warning.
Old Jan 24, 2007 | 11:28 AM
WTFWASTHAT?'s Avatar
I tried that and it works but I hear that some people were blowing fuses. Although the 06 does come with a 15amp fuse for the factory horn and I believe the earlier models had a 10amp.
Old Jan 24, 2007 | 11:29 AM
I read that the ABS is on the fuse too....Is that true? I would not want to loose all that at once!
Originally Posted by WTFWASTHAT?,Jan 24 2007, 02:26 PM
Sorry...So just to be clear.
Ground 86 and leave everything else the way it is in the pic?
Yes. Assuming you have the 85 connected to the OEM horn wire under the hood. If not, then I need more information.
Old Jan 24, 2007 | 12:10 PM
You are the man! It worked perfect! Thanks!!!
Old Jan 24, 2007 | 12:20 PM
Cool deal. You are welcome.
rob-2
Jun 14, 2012 08:02 PM
project*stealth
Feb 5, 2012 01:10 PM
macr88
Electronics
Feb 21, 2010 12:18 AM
pikkashoe
Oct 16, 2005 08:35 AM
SteveUCI
Aug 15, 2001 09:25 AM
