Wrap or no wrap
Old Jun 21, 2005 | 07:03 PM
BRYL13's Avatar
Default Wrap or no wrap
should I wrap my Js headers with Thermotec wrap or not.
Old Jun 21, 2005 | 10:06 PM
Ro_Ja Boy's Avatar
No
Old Jun 22, 2005 | 01:26 AM
CwestinAP1's Avatar
why not? unless you don't wanna cover up the bling?
Old Jun 22, 2005 | 01:29 AM
Silver_S2000's Avatar
Well a good reason not to "cover up the bling" would be because the heat wrap not only blocks heat from exiting the pipes and increasing under hood temps; but it also holds moister within itself causing your expensive J's header to rust and corode at a very quick pace..So unless you want to buy another J's header in a year or two...Leave the bling
~Cody~
Old Jun 22, 2005 | 01:40 AM
New Concept's Avatar
Banned
then what is the purpose of buying the header wrap in the first place?
Old Jun 22, 2005 | 03:56 AM
^ Race purposes....they use them on the track..You will see it on "Track Only" car's mainly...and they dont mind replacing the pipes after a year or two..they are used to replacing the engines on an annual basis..or even less depending on what motorsport you are refering to.
Old Jun 22, 2005 | 04:48 AM
freq's Avatar
How often does your car see rain? Rust may not be an issue. The wrap WILL REDUCE underhood temperatures. I have used it on my motorcycle exhausts with no ill effects. I also think that a wrapped header looks more "race" than a bling exhaust.
Old Jun 22, 2005 | 05:14 AM
I agree with you about the reducing the underhood temps....but the wrap itself holds moister...My car see's moister anytime it rains outside...My s is my daily driver...That's one reason I wouldnt ruin a good header.
Old Jun 22, 2005 | 06:41 AM
BRYL13's Avatar
How about a heat shield
Old Jun 22, 2005 | 07:28 AM
Voodoo_S2K's Avatar
A header wrap could also cause the header to develope cracks if it holds in to much heat.
