Wrong Octane!!
Old May 20, 2003 | 12:08 PM
NYMATT74's Avatar
Default Wrong Octane!!
I accidently filled up with PLUS rather than Premium. Do you think octane boost will offset my error? Or should I just drive non-vtec till the next time i fill up?
Matt
Old May 20, 2003 | 12:11 PM
DarioManfretti's Avatar
You should be fine. You can even go into VTEC if you want. Supposedly, a lesser octane will make the engine no peform to it's peak level.
Old May 20, 2003 | 12:53 PM
Ravenwerk's Avatar
Shouldn't be a real problem. Just listen for pre-ignition (pinging/spark knock/detonation). The computer will adjust the timing to compensate but you might feel some power loss.
Old May 20, 2003 | 12:55 PM
The Gasman's Avatar
you'll be otay!
Old May 20, 2003 | 01:03 PM
jojipoji's Avatar
You can always get a tube and siphon it out
Old May 20, 2003 | 01:16 PM
Crabby Guy's Avatar
The engine control will undoubtedly retard the spark and you'll be fine. Please let us know the impact on performance--good info if you're in the middle of nowhere and the one gas station is out of premium.
Old May 20, 2003 | 01:21 PM
Crabby Guy's Avatar
Ooops--clicked reply too soon.
The only thing that might be a problem is that your engine could possibly have some run-on (dieseling) after you shut off the ignition, especially in hot weather. Running like this is very, very bad for the motor. Solution: put your car in 6th gear, press firmly on the brake pedal, turn off the ignition, and then let the clutch out briskly, keeping the brake pedal depressed firmly.
Old May 20, 2003 | 06:43 PM
RazorV3's Avatar
in the manual it says its ok just for temporary uses, but you will definately loose power. if it starts pinging/knocking, syphon it out ASAP.
Old May 20, 2003 | 07:05 PM
aggie's Avatar
I could tell no difference in performance or economy for everyday driving in hot weather (Dallas) with regular gas. I use premium anyways just cuz
Couna777
Sep 16, 2015 10:20 AM
ZiTrO
Jun 22, 2011 02:16 PM
erikvanden
Apr 26, 2011 05:59 PM
cthree
Jul 20, 2007 07:51 AM
Purple Haze
Nov 15, 2004 05:58 AM
