*VIDEO* Squeak from rear wheel???
Old Jun 25, 2019 | 05:14 PM
DailyDrivenLBP's Avatar
Default *VIDEO* Squeak from rear wheel???
This noise began about three weeks ago and I still haven't been able to nail down exactly what it is. Anyways, here's some info on it:
-It is coming from the drivers side rear wheel
-It takes about 10-15 minutes of driving for it to start happening
-It is rotational (increases its frequency with speed)
-It is louder at lower speeds (5-15mph) and is almost unnoticeable above 50mph
-At first it will only happen when throttle is being applied
-Eventually it will happen all the time EXCEPT when the brakes are applied
-At first it will only happen when turning left
-Eventually it will happen all the time EXCEPT when turning right
-I tried the wheel bearing/tie rod end test (rocking the wheel at 9/3 and 12/6) but there was no play in either direction
Also: The car has BC Racing coilovers, Enkei RPF1's, Hankook Ventus V12 evo2 tires, and is VERY badly out of alignment.
Old Jun 26, 2019 | 06:11 AM
fatjoe10's Avatar
This is hub and bearing noise. Replace both at the same time.
Old Jun 26, 2019 | 03:58 PM
What makes you know it's the hub too and not just the wheel bearing? Also wouldn't one wear out before the other?
Old Jun 27, 2019 | 09:31 AM
fatjoe10's Avatar
The hub has lost its press fit with the inner bearing race. The squeak you hear is the hub moving as you drive.
LowMayne
Mar 28, 2017 09:56 AM
Drdoc
Nov 15, 2015 05:36 PM
Jimbogiant
Sep 12, 2015 04:44 PM
J.nguyen
Dec 4, 2008 04:40 PM
