Wheel Bearing
Hello s2ki I need your help, I have '00 s2000 with a load scraping noise coming from the drivers side rear wheel. Now I'm pretty convinced that it might just be a bad bearing based on the driving conditions.
It get loud when:
Making a right turn and no noise when I make a left turn,
When I slow down to about 30mph or slower at higher speeds it sounds like it's chirping,
Braking makes no difference in the noise.
I also lifted the rear wheels in the air and no free play on the tire or rotor + when I spun the wheels by putting in first gear no noise, so it only makes it under load.
I have a video I just wanna hear your opinions before I go ahead with replacing the bearings
https://www.youtube.com/watch?app=de...&v=z9YnnCc-kb4
It get loud when:
This is true. If you're handy and can drag the knuckle to a local shop to press out/in the bearing/hub to get away with replacing wheel bearing/hub for ~100$ (parts+labor)
i've had bad bearings which have a horrible howling sound- it reverberates and pierces my brain. I thought it was an exhaust leak of manic proportions, but no, bad bearing.
Fairly straight forward repair if you have the tools and bearing press.
good luck
darcy
good luck
darcy
