00 S2000 clutch problems
Old Apr 18, 2013 | 03:55 PM
b00st2r's Avatar
Default 00 S2000 clutch problems
I have a 2000 s2000 with 103k on it, i bought this car last year with about 100k on it. The clutch engagement point was okay when i first bought it but right now it engage right at the top of the pedal(litterally engage and disengage right at the top).
I have tried adjustment the master cylinder rod which changes the pedal height but the engagement point still engage at the top which make it hard to take off from a stop
smoothly..
I have also flushed the clutch fluid and check the master cylinder and did not see any leaks, the clutch is not slipping. I could floored it in any gear at rpm and it will hold and not rev aka slipped. I can dump the clutch at 6k from a stop and it would actually bogged down, i think my clutch is worned down and need replacement but its not slipping yet but the previously owner said the clutch was recently replaced which is strange.
Does this sound like a worn disc causing high engagement point and need clutch replacement or possibly a slave/master cylinder problem? maybe the previous owner lied about the clutch being replaced?
Old Apr 18, 2013 | 06:33 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
High engagement is 95% a worn disc.
zakazak
Sep 27, 2013 07:34 AM
mezzfin
Nov 11, 2010 02:51 PM
Pezza
Nov 27, 2007 10:15 PM
Big_Al
Nov 11, 2005 11:45 AM
bunjimobile
Mar 31, 2005 04:35 PM
