02 sensor
Old Feb 2, 2010 | 04:45 PM
xasrielx's Avatar
Default 02 sensor
im trying to change my exhaust. i've broke lose the first o2 sensor in the header no problem ( as i had to change header) and i got it back in. but the 2nd o2 sensor on the exhaust part wont budge for anything. my 24mm wrench slips. so i got vise grips on it as hard as i can and it still wont budge.
anyone think they can help?
Old Feb 2, 2010 | 04:55 PM
Mister Jew's Avatar
soak it in pb blaster and use a set of vice grips. mine was on there very tight but i let it soak and use vice grips and it came off easy
Old Feb 2, 2010 | 04:59 PM
Slows2k's Avatar
It should be a 22mm not a 24mm. All OEM sensors are 22mm
Get a 02 sensor socket.
Old Feb 2, 2010 | 05:01 PM
xasrielx's Avatar
all oem sensors are 22mm? i know i had to change my vtec oil pressure sensor b4 and that was 24mm and the first o2 sensor fit the 24mm wrench i have...
Old Feb 2, 2010 | 05:06 PM
zeroptzero's Avatar
you were lucky on the first sensor, it is 22mm, I just pulled both of mine. An o2 sensor socket works well too, you can actually torque it to spec with an o2 sensor socket, otherwise a 22mm open end wrench will do it.
Old Feb 2, 2010 | 05:47 PM
xasrielx's Avatar
ok well i dont have a 22 mm -.- lol sucks
ima just blast it with wd40 and use vise grips.
and then when i get the money i'll go buy a 22mm
Old Feb 2, 2010 | 06:42 PM
iam7head's Avatar
please do not soak the o2 sensor with anything, apply what you need and use a proper tool
those sensor are well over a hundred a pop adn they are very very fragile.
please save those new york wrench for home improvement project and get rent an o2 sensor adopter at autozone, did i mention it's free rental?
Old Feb 2, 2010 | 06:48 PM
xasrielx's Avatar
i didnt litterally mean soak it. i just applied it to the rusted bolt part a little around in a circle.
and i tried autozone and they didnt have any at mine ( our autozone sucks)
btw the wd40 and vise grips did the trick on the first try
s2knOOb02
Jan 17, 2008 08:06 PM
AROD
May 28, 2007 12:16 PM
