02 sensor High Voltage
Old Oct 9, 2006 | 06:07 PM
Kenpo_S2000's Avatar
Default 02 sensor High Voltage
I no longer have my misfire codes woo hoo! Instead I have P0136 and P0138. 136 is 02 circuit malfunction Bank1 Sensor2
138 is 02 sensor circuit high voltage bank 1 sensor 2
The previous owner had an 02 simulator installed. If this was done improperly or the box is bad could this cause these codes? I have a test pipe so I will need some type of simulator.
If it is not the 02 simulator, where do I go from there? Replace the sensors?
Old Oct 9, 2006 | 06:55 PM
Ek9's Avatar
Ek9
Banned
Those are both secondary O2 sensor codes so, I'd say yes, it's likely.
Bank #1 Sensor #2 is the key. It's telling you it's the secondary sensor.
Old Oct 9, 2006 | 07:19 PM
On Friday we are going to check everything out hopefully it will be as simple as that.
jdmjunkie562
Nov 7, 2009 11:09 AM
Kenpo_S2000
Jun 12, 2007 06:12 PM
s2k_jay
Apr 11, 2007 04:04 PM
