04/05 headlights
Old Oct 14, 2004 | 01:18 PM
Surfanswim's Avatar
Default 04/05 headlights
anyone know how to take out hi beams of the newer headights? i cant seem to get them out, btw i dont have an owners manual, they had to order one for the 05, apprently it didnt come with it, stupid dealers, lol, thanks
Old Oct 14, 2004 | 06:08 PM
xviper's Avatar
I would be inclined to think that they are either lying or are clueless as to where the owner's manual might be. Have you looked in the secret compartment?
Old Oct 14, 2004 | 06:12 PM
nibble's Avatar
I'd agree with xviper but you may not know where the secret compartment is if you don't have a manual.
Old Oct 14, 2004 | 06:31 PM
Surfanswim's Avatar
I know where the secret compartment is, the dealership was like its in there, i was like really where, there like, uhhhhhhhhhhhh, I dont know then, were order you one. stupid stupid people
Old Oct 15, 2004 | 01:09 PM
Surfanswim's Avatar
so does anyone have any idea how to take out the high beams H1 lights?
Old Oct 15, 2004 | 03:45 PM
Road Rage's Avatar
Mine called out to me - like the Ring does to Frodo. But the Vial of Galadriel helped me when in dark places, such as the notorious chamber Harry Potter, and S2000 owners, seek.
Old Oct 15, 2004 | 04:40 PM
Surreal_S2K's Avatar
I just replaced mine. (Thanks to all who recommended new H1s)
Pull connector off.
Remove rubber boot. This is somewhat difficult as the front edge locks in for a good seal. It takes a little patience, but once you raise one edge, it will pull right off.
Look inside... There is a spring clip that must be pushed in to disconnect, this pivots back out of the way once disconnected. Careful, when the lower portion of this spring mechanism swings away the bulb will be free.
Pay attention to the orientation on removal, there are two 'projections' that align the bulb on reassembly.
Pull old h1 from socket and replace.
Clean new h1 with alcohol to eliminate oils from hand.
Reinstall in reverse order.
It helps to peek through the headlight to help with assemble alignment.
Patience......
By the way, which brand did you select?
Old Oct 15, 2004 | 05:17 PM
Surfanswim's Avatar
Thanks dude, I will do it tomorrow
I selected MTEC 3,300K 100w
Should look sweet, Ill post pics when I install them, thanks again
Old Oct 16, 2004 | 04:47 AM
Ok, I rolled around a little trying to sleep last night. The old H1
removed from the s2k is listed at 55 Watts on the back alignment plate.
Power in Watts / Voltage in Volts = Current in Amps (Current wants to melt wires)
Bigger wires carry more Amps .
Original H1 : 55 Watts / say 12 Volts (Engine Off) = 4.6 Amps
My Sylvania Silverstars : 65 Watts / 12 Volts = 5.4 Amps
Your H1 : 100 Watts / 12 Volts = 8.3 Amps
I am not sure what the factory wiring is capable of. You might want to find out by calling Honda or asking one of the others listed above on this thread. They are very knowledgeable individuals. High power light kits from Hella and such have a design limit of wattage where they add an isolation relay to the circuit and use heavier wiring to handle this increase in current. The factory wires only handle the current required to turn this relay on or off.
Also, heat takes time to build (inverse time-current curve, more current = less time), the problem may take some 'on time' to appear. This generally happens at a really bad time of day...(night).
Ask me, I did this to a Camaro some 15 odd years ago.... If you find success, let me know. I may step up the wattage as well...
Good Luck.
RonnieG
Apr 22, 2013 11:15 AM
PhenomS2k
Jul 17, 2006 07:49 AM
BobsS2000
Aug 5, 2005 10:36 PM
wwwracer
Nov 22, 2004 03:50 PM
GodoftheBOLP
Jul 20, 2004 04:58 PM
