Spring install, alignment bolt?
I turned the 17mm bolt that bolts the lower control arm to the body of the car when doing my spring install (by accident of course). This is the bolt that has a 17MM nut on one side and a 17MM bolt on the other with notches around it, looks like it is used to align the suspension.
I just set it back to what it is on the other side of the car, should I be OK for now?
