'06 S2000 Drive By Wire Stumble
Originally Posted by WayneTeK,Feb 1 2006, 12:43 AM
this thread doesn't make sense..
Originally Posted by Yflyer,Jan 31 2006, 09:58 PM
So you ar sying that the Drive-By-Wire throttle has been programmed to produce the same hiccup?
Or are you sying that the hiccup is endemic to the S
Its common for ANY standard car to "buck" slightly when going from completley off the gas to on the gas, while staying in gear and not using the clutch at all.
You don't program something like this "into" the car. The car (any manual car) has this characteristic. I suppose Honda could have programmed this "out" of the car, but then you would really have very slow throttle response the rest of the time.
When you are decelerating, the rpm is dropping. If you then stomp on it, you are asking the engine to motivate the weight of the car from that lower rpm, where there is less torque and HP. You are also reversing all the driveline lash. It is natural to get a "stumble" when you do this. If you don't want this "hiccup", then don't stomp on the gas so rapidly when you transition from decel to accel. Or learn when to clutch and when to downshift, in which case, you'll get a stumble or hesitation when you do the shift or do the clutching or both.
Some of you really need to learn basic auto mechanics and drivetrain function.
Engine above a certian rpm, zero throttle, fuel gets cut off, less pollution and higher mileage and no exhaust backfire noise. So your are coasting than nail the peddle, a moment of no power as computer restarts fuel flow.
Alright, I know engines an fuel systems pretty well. I've driven manual tranny's for over 30 years and I can manage low rpm and high rpm performance as well as anyone.
Indeed, modern cars use fuel shut off on trailing throttle while in gear. I just sold a VW Passat 1.8T 5-speed. The multifunction display (VW speak for computer display) would blank out on trailing throttle, indicating infinite miles per gallon (i.e division by zero if you understand this).
NEVER did it stumble coming back after trailing throttle, and neither does my '94 Acura GS. Now, don't start dissing all the other problems with the VW -- that's why it is gone and the S is my 5the Honda product. I CURRNETLY own -- 3 Odyssey's 95/95/98, 1 Acura 94, and the S 06. I am used to any Honda quirk.
Everything else on the car is so well engineered that this flaw really irritates. don't excuse it or explain it away.
Buh-Bye!
Originally Posted by xviper,Feb 1 2006, 06:47 PM
Oh, and I'll "excuse" it or "explain" it as I please. Buh-Bye!
End of discussion
Everyone take a chill pill...
Bassem
And why in the hell would any man own 3 Odysseys? I mean, it's a great vehicle, now, but those years? And 3 of them? How many children could you possibly have? How many groceries do you need to pick up.
Wouldn't it be easier to just get a bus? Or hell, since you like VW so much, where's the Eurovan?
If you're not happy with the performance of the vehicle and think something is wrong, take it to the dealer and ask them to fix it. I don't think driving lessons are covered under warranty.
You test drove the car before you bought it or at least had the opportunity to test drive it and did not complain at that time. There is nothing wrong with the car, get over it and get used to it or get rid of it.
my car does the same thing if i try to reproduce what you're stating.
