1-2 shift grinds on AP2
Old Jan 2, 2008 | 08:29 AM
Tee-Dub's Avatar
Thumbs up 1-2 shift grinds on AP2
My transmission grinds on the 1-2 shift when accelerating hard. Car is a 2005 w/25000 miles, trans fluid replaced about 1k miles ago. I saw the service bulletin for this on the FAQ section, but it was issued back at the inception of the s2000. Does this still apply to the newer vehicles?
Interestingly enough, the service bulletin says to test drive the car, but not to exceed 4k rpm for the first twelve 1-2 shifts! Seems hard to tell if that fixed the problem if the tech can't accelerate hard when testing the car!
Old Jan 2, 2008 | 08:36 AM
Kaos_theory's Avatar
same thing and I have an 06 with 8k on it. Bringing it to honda in the spring
Old Jan 2, 2008 | 09:27 AM
camuman's Avatar
this is a shot in the dark, but some 1-2 grinds in s2000's happen from shifting to fast and not stepping all the way down on the clutch. i would here and there scratch 2nd and when i slowed down and made sure the clutch was all the way down, problem disapeared. its hard to tell a honda tech : " hey when i drive really hard and shift 1-2 fast it grinds". also make sure your not pullling the stick from 1-2 before going down on the clutch. just a thought.
you could also try redline mtl fluid. 05's had that crap fluid in them.
Old Jan 2, 2008 | 09:45 AM
Hockey's Avatar
Exactly what the above poster stated. Over the years I've learned that the 1-2 grind is mostly driver error. Try a closer seating position. Really.
I have a MY00, and used to say I have the 1-2 grind. What transmission fluid do you use? I switched to Redline MTL and it helped with my notchy shifter. Over time and experience with the car, the 1-2 grind went away on its own. Since I know things don't typically fix themselves.....I've concluded that I simply learned how to shift the car better. Now when I jump on it (last night for example) 1-2 is fine.
-Hockey
Old Jan 2, 2008 | 10:03 AM
Tee-Dub's Avatar
When I replaced the fluid I used the Factory Honda stuff. After doing research here it seemed that was the way to go.
Old Jan 2, 2008 | 10:14 PM
jyeung528's Avatar
yes sir.
Old Jan 3, 2008 | 12:03 AM
CBR2200's Avatar
Also make sure you're pulling straight back into second. I found my 1-2 shift notchy-ness issue was actually caused by me pulling ever so slightly towards my body instead of straight back.
Old Jan 3, 2008 | 12:12 AM
8overgixxer's Avatar
i've only been driving my s for a few weeks and i had the same issue. it wasn't the car. It was me and I freely admit it.
I was surprised to see that someone else already mentioned this as I thought I had an epiphany the other day when I did this. I pulled my seat forward 1 click. fixed it completely. it seems that my s really wants you to put the clutch to the floor from 1-2.
I played with it a little and it's just my 1-2, if I'm even a fraction of an inch off the floor, it feels notchy and bleh, but if i'm on the floor it's like butter
kenlola
Nov 13, 2004 05:42 AM
kenlola
Oct 30, 2004 11:15 AM
s2kkid
Oct 10, 2001 05:59 PM
Clovis
17
Feb 22, 2001 04:51 AM
Clovis
Feb 8, 2001 07:23 AM
