100 octane!
hehe koolz, thanks the for the input guyz...next time i'm goin with jus str8 91...which is usually the highest offered out here in the Bay...So I should maybe run a cleaner after this tank since it leaves more deposits?
JanNov s2k, your ECU learns what octane you have by listening to the knock sensor. That's why you can even run it on 87 and not hurt the engine any. Your power will be way down but, it'll run and it won't hurt anything.
The ECU does all sorts of magical things like, compensating for worn spark plugs and dirty throttle bodies. Read up on it some. You'll see what I mean.
Originally Posted by Lino8419,Jul 27 2006, 11:42 AM
i thought higher octane was just better for not having to worry about detonation and things of that nature....not really for power.
because of low compression, the car will start build up slugish oil on the valve..(which is unburned oil)
it'll start to build up like black things you see @ chervon commerical.
Originally Posted by JanNov s2k,Jul 27 2006, 12:31 PM
but for a stock 00-05 ecu and no mods it is useless. 00-05 ecu's are not programmable.
like i said before your jus wasting your money!
Originally Posted by gomarlins3,Jul 27 2006, 06:40 PM
I have finally found something that I disagree with xviper on.
Actually church automotive did a comparision test of a car running 91 OCT gas followed by an ECU Reset and 100OCT gas. I forget the exact numbers but the gains were significant.
I've actually used 100OCT last summer when the gas prices rose above $3 a gallon, and while I'm always a skeptic of the butt dyno(they have a history of being miscalibrated). I will say that I do agree that it felt much stronger than on regular gas.
