110 octane gas!!??
Old Jan 29, 2003 | 06:29 PM
SoDakS2K's Avatar
Default 110 octane gas!!??
Just wondering if anyone has any opinions on putting this in my car? Only mods are intake and exhaust. I'm not considering running on this gas alone. I would mix it with 93 octane, unless you think it's safe?
Old Jan 29, 2003 | 06:44 PM
Ubetit's Avatar
With the mods you listed there really isn't any reason to run higher octane than 93.
Old Jan 29, 2003 | 06:55 PM
SoDakS2K's Avatar
I lookes over some older posts about kind of the same topic. Kind of answered my question. I ordered the test pipe today from SC Suzuka. Will that make any difference, or as stated before, that it only really benefits SC or turbo cars? The rumors aren't so true that the higher octane will boost hp?
I was thinking about debadging my car on the side, too. Any chance you have pics?
Old Jan 30, 2003 | 12:51 PM
schwett's Avatar
if everything else is constant, higher octane fuel does not produce any more power than lower octane fuel.
if, however, running higher octane fuel allows you to advance the timing, or prevents the stock ecu from retarding the timing, then it would make more power. in this case, neither of those is true, so it will make no difference at all.
Old Jan 30, 2003 | 12:59 PM
Yellow Streak's Avatar
I am under the impression that since very high octane is harder to ignite, it can actually cost you horsepower when you run it in an application that doesn't need it.
-YS
Old Jan 30, 2003 | 10:49 PM
Nobody's Avatar
Make sure the 110 isn't leaded!
Old Jan 31, 2003 | 05:13 AM
KeithD's Avatar
110 is usually leaded. 100 isnt.
Old Jan 31, 2003 | 05:52 AM
[QUOTE]Originally posted by KeithD
[B]110 is usually leaded.
Old Feb 1, 2003 | 11:22 PM
Nobody's Avatar
Should I even mention Toulene?
Old Feb 2, 2003 | 04:33 AM
Sure. And then mention Toluene
-YS
galiff
May 25, 2011 04:42 PM
slanguage
Apr 24, 2006 04:27 AM
Stw000
Mar 27, 2005 10:13 AM
SJSHARKS
Jul 11, 2003 04:45 PM
VisualEchos
Dec 9, 2002 07:30 AM
