12 volt outlet
Old Sep 25, 2001 | 02:38 PM
Oscar Dufau's Avatar
Default 12 volt outlet
Has anyone tried putting a cigarette lighter in the 12 volt outlet?
Old Sep 27, 2001 | 04:08 PM
Utah S2K's Avatar
Not compatible with the outlet........
Ref: Honda Owners 2001 Owners Manual Page 80
"Accessory Power Socket ......it will not power an automotive type cigarette lighter element".
Sorry it took so long to resopnd to your inquiry but I don't smoke. As no one else ponied up an answer....well.....know you know.
Old Sep 28, 2001 | 07:39 AM
Wesmaster's Avatar
Another note. Joe_S2K was able to blow both his and my fuse using the power outlet with an electric air pump designed to be used with car outlets. Maybe the device was heating up / pulling too much current, since many people had used it prior to that. Just an FYI.
Old Sep 28, 2001 | 12:56 PM
Thanks for the response, I had read the warning in the manual and was just wondering if anyone had modified the outlet so that it could be used for something other than a phone charger?
Old Sep 28, 2001 | 01:11 PM
bbsilver's Avatar
It can be done. Run a fused line directly from the battery, just like an amp. The wire is the limiting factor. The low fuse value is to protect that wire from overheating. Don't know the current rating, but that is the upper limit on what you can run without modification.
siadam
Aug 24, 2011 11:20 AM
Jason Milner
May 11, 2006 08:47 AM
CaptKirk
Sep 26, 2005 08:48 PM
smart_sio
Nov 29, 2004 04:08 PM
marc
Jan 21, 2002 07:39 AM
