Check Engine Light
Old Sep 28, 2001 | 05:55 AM
daves2k's Avatar
Default Check Engine Light
My Check Engine light came on this morning. Should I get to the dealer now or can it wait until Monday?
Engine is running fine, plenty of fluids.
Thanks in advance,
dm
Old Sep 28, 2001 | 03:11 PM
Utah S2K's Avatar
Anywhere near 6,000 miles? Your car may be telling you of a pending oil change. If not post here.
Utah
Old Sep 28, 2001 | 03:26 PM
bbsilver's Avatar
I believe the check engine light will flash, not stay on when you approach the 6K mark and remain on after that. There is a tutorial in FAQ section. The dealership will tell you to do the following so you might as well do it now. The gas tank is pressurized and there is a sensor that checks it status. It does cause a check engine light. (Speaking from experience )Remove and reinstall your gas cap as well. 3+ solid clicks.
beefystud
Oct 28, 2016 09:13 AM
RASHID007
Mar 7, 2010 08:13 PM
gochuxsaurus
Aug 10, 2005 07:37 AM
vdiggy
Sep 12, 2003 09:26 AM
yogi
Nov 6, 2000 04:24 PM
