2,500 rpm
If you're using the same sensors/harness/ecu for the motor, it'll behave largely the same. I don't know the exact number, but mine idles relatively high when it's cold. ~1k (usually below) once it's warmed up.
But how does one rotate the gearbox output shaft and not rotate wheels / move car?
Car on jackstands, in gear, engine running?
Just asking.
Originally Posted by chris_barry' timestamp='1349744337' post='22068327
If the output shaft of the gearbox is turning it will idle faster. The ECU needs to think the car is stationary before it drops to normal idle.
Just asking.
Originally Posted by lotus7racer' timestamp='1349729518' post='22067738
Oh well, I turned off the ignition, I'm worried on the hi-idle.
Maybe I will let it idle until it gets hot.
My car is not s2000 only the engine that is a s2000.
I still feel the 2,500 rpm way too high (cold) what else to look to lower it below 2,000 rpm atleast?
The TPS properly set up. 0.30 at rest and 4.5V at wot. Nothing unhook - IAC very clean and moving. Linkage & idle screw are properly set.
New intake and throttle body gaskets.
Just asking.
Wisconsin S2k
Apr 18, 2025 01:26 PM
