2003 Engine
Old Mar 16, 2004 | 12:12 PM
scottcal444's Avatar
Default 2003 Engine
WANTED TO KNOW IF THE 2003 ENGINE IN A S2000
IS THE SAME FOR 2001/2002 ?
Old Mar 16, 2004 | 12:28 PM
CoralDoc's Avatar
NO
If you care to elaborate on what differences you're concerned with, we could give you a more detailed answer.
Old Mar 16, 2004 | 12:43 PM
CyrusA's Avatar
the engines are different? how so?
Old Mar 16, 2004 | 12:55 PM
I NEED AN ENGINE FOR A 2003
WANTED TO KNOW IF I FIND ONE
OUT OF A 2001/2002 THAT IF IT
WOULD WORK.BECUASE NOT HAVING
MUCH LUCK FINDING ONE OUT OF
A 2003.
Old Mar 16, 2004 | 12:56 PM
redsound's Avatar
you need to worry about finding the caps-lock button first.
Old Mar 16, 2004 | 01:04 PM
sorry about that lol.
Old Mar 16, 2004 | 01:11 PM
ACLR8's Avatar
as far as I know, the ECU is different between 00, 01 and 02/03.
That is the ECU was programmed more aggressive for 02/03 and it ran less rich.
I don't know of any other differences.
I'm sure numerous experts will chime in quickly and point out how ignorant I am.
Just telling you what I know.
Xviper might be the guy to talk to. he probably has a DIY engine swap thread. He is very knowledgeable
Old Mar 16, 2004 | 02:16 PM
RazorV3's Avatar
oil jet bolts
Old Mar 16, 2004 | 02:24 PM
AusS2000's Avatar
The basic shortblock and head are compatible. There are some minor differences. For example, the oil jet bolts for 00-mid 02 are two hole whilst the mid 02 onwards are 4 hole.
Not a big enough difference to worry about, and if you are worried, just upgrade the oil bolts during engine swap.
Old Mar 16, 2004 | 05:13 PM
CoralDoc's Avatar
As stated above, there are differences in the ECU and in the oil jet bolts. If you want to get an engine for an '03, you're best off with one out of a later '02 or '03, but an earlier '02 will do (same ECU was used in '02/'03) if you don't mind the old design oil bolts.
