2004-2009 existing slave cylinder mod
Old 01-29-2007, 10:00 AM
  #111
K-Lo's Avatar
did this mod yesterday and all i can say is WOW! the car now jumps forward after each shift. definitely worth it.
Old 08-24-2007, 09:28 PM
  #112
gdmlaz's Avatar
damn i hate this about my 04 i feel the slippin when shiftin it hard can we get some pics on how to do this
like a pics of the process i don't wanna mess it up
Old 08-25-2007, 09:14 AM
  #113
gdmlaz's Avatar
wow im doing mine right now and im so aggrevated with that stupid snap ring any suggestion on how 2 pop it out
Old 08-25-2007, 10:53 AM
  #114
gdmlaz's Avatar
ok finally done and i couldn't be more satisfied it feels like i put a clutch on the car feels like a totally different car :-D
Old 08-25-2007, 03:19 PM
  #115
LubedKoala's Avatar
Can I just go to the dealership and have them install an '03 CDV without any problems?
Old 09-16-2007, 06:03 PM
  #116
verviers's Avatar
Man that Snap Ring was impossible!!!..
Let it be known that your pick will need to be real sharp to pop the snap ring out.
I took a large 2"+ safety pin shown here with bent the tip. When the ring came out, it came flying out, so do this in a place that will allow you to find it...
Good luck you may need it!
And the result you ask... I still get clutch slipage..
!#@!!f!!K*^%
Above...
And No, Honda dealer won't install that for you, if they do it will be at $100/hour and they can get in trouble with the factory for doing it... I'd just buy the part and give it to a local mech if you don't wanna do it yourself.
Old 10-04-2007, 06:03 PM
  #117
MADANT15's Avatar
I used a set of mechanics pics from autozone. The snap ring put up a fight, but I was finally able to get it out after 1/2 an hour. Just remember to tighten you bleeder valve well after you bleed your clutch! I only hand tightened it like a dumbass, which resulted in it coming loose during my first redline shift after the cdv mod. I had to re bleed my clutch on the side of the road, not fun. This mod make a huge difference in clutch grab and feel, however I occasionally still get slippage on my 1-2 shift, but this is probably because my car had 18k miles when I took out the cdv...
Old 04-03-2008, 01:04 PM
  #118
nichigo's Avatar
does anyone have any pics of where this valve is actually located on the car?
Old 04-03-2008, 01:19 PM
  #119
Elistan's Avatar
It's inside the slave cylinder (the light colored on is the AP2 one, under the black cap on the top right)
The slave cylinder is on the side of the transmission:
Old 04-03-2008, 02:00 PM
  #120
nichigo's Avatar
ok thanks...how hard is it to access/remove the slave cylinder from teh tranny?
Quick Reply: 2004-2009 existing slave cylinder mod
