4th Gear TSB Question (MY01)
Old Mar 1, 2005 | 06:33 AM
FoxMan's Avatar
Default 4th Gear TSB Question (MY01)
This is a question to anyone that has had\performed this TSB. I recently had it done and now the shifter does not return to center when you take the shifter out of 5th or 6th gears. It just lays over to the right side. The dealership insists this is normal operation until a ball at the bottom of the shifter wears. However, if I take the shifter out of 1st or 2nd gears, the shifter returns to center.
I think they're giving me a load of BS and am awaiting a District Rep's call. But if they're telling the truth, I don't want to be an ass. Thanks in advance.
Old Mar 1, 2005 | 07:13 AM
xviper's Avatar
There is a set of springs that center the stick. One for each (side to side) direction. Just in case the guy's right about a sticky "ball", can you feel any return resistance as you gently move the stick to the right? Or can you move it slightly, take your hand off it and it will stay where you left it? If this is the case, it's more than likely that when they did the job, they did not re-install the right to left return spring.
In any case, this is NOT normal operation. If it is a sticky ball, this can be "unstuck" (lubricated). I have a feeling it's not just a sticky ball.
Old Mar 1, 2005 | 07:34 AM
FoxMan's Avatar
I can't feel any resistance when I move the stick. It's actually much smoother than before the service. If I move it partially right and let go it will fall to the right after a short while. (30 seconds or so)
Thanks for the help.
Old Mar 1, 2005 | 07:52 AM
xviper's Avatar
This tells me there is no spring attached to that side.
Old Mar 1, 2005 | 03:07 PM
Slows2k's Avatar
After a quick look at the manual, it may be they assembled the trans with the detent springs in the wrong location. There are 7 detent springs and balls, with different springs going in different locations.
Hs2ktc
Feb 15, 2016 07:11 AM
CarlTrooper
Jul 14, 2013 03:25 PM
AusS2000
Feb 11, 2008 10:42 AM
Chubbikin
Jun 8, 2005 08:13 PM
thunderchicken
May 5, 2003 07:41 AM
