6th gear / reverse question
Old Jul 14, 2013 | 02:13 PM
CarlTrooper's Avatar
Default 6th gear / reverse question
Hey guys ! Super pumped just got my new (03 with 13k miles) s2k!!! Drove 2 hours home and never had a 6 spd before. I was curious if this car can accidentally be shifted into reverse by accident. I was kinda nervous throwing it in 6th.
Love the car! Can't wait to learn more
Old Jul 14, 2013 | 02:20 PM
realblag's Avatar
You would not be able to misshift into reverse by accident. It would take alot of force and there would be much grinding. You have to kinda push down on the shifter for reverse anyway so unless you are doing that on the rest of the gears for some odd reason......
Old Jul 14, 2013 | 02:39 PM
takeshi's Avatar
Try putting it into reverse (you can do so stopped -- no need to test this while moving) and you'll have your answer.
Old Jul 14, 2013 | 03:23 PM
How does that answer it? I know you have to push down I just wasn't sure ifyou tried to downshift and pressed it down it would go in reverse.
Old Jul 14, 2013 | 03:25 PM
baZurk's Avatar
You will be fine. Like mentioned above the shifter will require a TON of force to put it in reverse while you are moving forward. You will know if you are doing it wrong
redlinernyc
Apr 9, 2015 05:59 AM
SlideWayz
Aug 26, 2012 04:19 PM
AkirA_JJ
Jan 13, 2010 12:53 AM
TomsalIII
Jul 2, 2009 11:24 PM
WeezyBaby
Jan 10, 2007 03:38 PM
