75W-90 vs 75w-110 DIFF fluid
Old Aug 18, 2011 | 12:57 PM
redbaron's Avatar
Default 75W-90 vs 75w-110 DIFF fluid
I"ve seen some threads on this but wanted to ask this question to more of specific scenario, i live in GA and its hot as crap here, i just got 4.77 gears on my diff and i know some whine comes with that and its about time to change the fluid from the break in period, now i was wondering of running 75w-90 would help or going with Amsoil severe gear 75w110? which is what most guys on here swear by... help please
Old Aug 18, 2011 | 01:03 PM
MasterForce's Avatar
any of those two is good. i personally use the amsoil severe gear 75-110 for my puddy mod diff.
Old Aug 18, 2011 | 01:06 PM
redbaron's Avatar
How's your wine with that oil? And where are you located? Like how does it get?
Old Aug 18, 2011 | 01:55 PM
zeroptzero's Avatar
definitely go with 75w110. I'm running 75w140 Amsoil in my stock diff in hot weather use and I find that it works quite well. Just my opinion.
Old Aug 19, 2011 | 06:15 AM
the whine you can hear it with decel which is pretty normal. in located in tx
Old Aug 19, 2011 | 07:48 AM
TougeS2k's Avatar
From reading the compiled oil logs it seems like even 75w-90 is too light. But i couldnt find any of that LE 607 stuff so i just went with Royal Purple 75w-90. If you live in a hot area, wouldn't you want it more thick?
Old Aug 19, 2011 | 07:55 AM
Biohazard's Avatar
I am using Amsoil Synthetic 80W-90 Gear Lube works great
Old Aug 19, 2011 | 11:23 AM
JackS's Avatar
The lighter weight should have better constant lubrication due to its weight. The heavier lube should have a better start-up protection due to the residuals and less "drip-away" when parked for extended periods of time. I'm pretty sure this is the reason for multi-weight oils and lubes to begin with. Which is better to use? I don't know.
Old Aug 20, 2011 | 03:27 AM
redlineracing's Avatar
IMO....for daily drivers,the 75-90 is just fine.For track use or in really hot climates,go with the 75-110.
I favor the Amsoil brand.I run the 75-90 in my 03S & 02Z06.
\rlr
carolina
Old Aug 20, 2011 | 05:11 AM
shawnIam's Avatar
Im running the Amsoil severe gear 75w-110 and its doing great so far! Gets pretty hot and humid in Tennessee also.
