75w90 + 75W140 ok for differential
Were talking about oil. The thickness will differ at 100C but the consensus is that its safe. When using dissimilar brands you might have one manufacture use zinc and another use idk moly for anti wear. This combination might not be ideal. I'm not a expert.. But personally I won't be concerned mixing the 140w with 90 if I only had half a bottle of each. Otherwise I'd use the 90 until the summer season then go with a 110 or 140. Really splitting hairs here.
So basically when Honda first engineered the S2000 they intended to have a fluid in the diff that was closer to todays 110, and not as thin as todays 90 spec.
There are more Amsoil dealers than there are insects in the world thanks to their marketing structure , it should be very easy to find or order on-line. When it comes to the differential, thicker is better. The sump capacity of the diff is very small and it needs all the protection it can get.
I've had amazing results from LE1605 which is SAE110. I have used Amsoil 75w110 and Amsoil 75w140. The previous owner of my car used Redline 75w90, which I think is going in the wrong direction away from the SAE90 of the original spec in 1999. With todays revised fluid classification the old SAE90 is closer to 110 than it is to 90.
Unfortunately when I sent in my used fluid sample of Amsoil 75w110 it got lost in the mail and I never got the results of that run Going by the paste that was visible on the magnetic drain plug I would say the 75w110 had the largest amount, 75w140 had less, and LE1605 had the lowest amount. I never noticed anything different between 75w110 or 75w140, they both felt good to me, fuel economy seemed to be the same as well. You would be safe running either viscosity, if you don't track the car then 75w110 would be fine for street use, if you do track the vehicle or run it in really hot temps then 75w140 would be a safe bet. You cant go wrong with either.
One caveat with LE1605, it gets really thick in cold temps, I would not want to run it in any winter driving conditions, for cold temp operation the multi-grade fluid like 75w110 is a better choice.
Think I will give the 140 a try, it seems more protective than the 110 and you still had 2x the wear as LE, not sure I want to go less. The car will hopefully see some track time and certainly autox time. Plus I have the 110 now, so if I notice any big differences I can put 110 back in the next time around.
Where do you live in the states? I would take JFUSION's advice over my own (he's very knowledgeable and objective about oil-related topics, among other topics). But the one thing that just sits funny with me is that cold start with 140. Have you seen this stuff at room temp? It's practically a solid. You pretty much have to warm it up in the microwave to be able to even pump it. So for the first however long into your drive (street or track) that stuff is a solid I would think. My advice is not in research or experience, just observation, so you can definitely take it with a grain of salt.
