Abs connector
Old Sep 19, 2012 | 09:33 PM
Mister Jew's Avatar
Default Abs connector
Just had a quick question the abs light is on in my car and I did the self diagnosis test and it is the front right wheel. I have a spare sensor but it is a rear I believe. I was thinking instead of buying a new sensor could i just cut the connector off and solder it on? That's the only difference i noticed between the 2. They mount a little different because of the little metal bracket that holds it to the upper control arm but that comes off as well so that would be easy. What do you guys think? I don't see it being an issue at all but wanted to see what you guys thought. Thanks
Old Sep 22, 2012 | 11:18 AM
Mister Jew's Avatar
Nothing?
Old Sep 22, 2012 | 02:41 PM
Si2k's Avatar
You will need to drive the car so that the code clears. The abs needs to see a signal from each wheel
Old Sep 22, 2012 | 05:46 PM
downloader's Avatar
Give it a try you have nothing to lose. Your front sensor is already shot.
AC50
Oct 18, 2017 11:26 PM
GTDRIFT
Feb 21, 2017 12:39 PM
FOXCONN4
Nov 29, 2006 07:57 PM
kMfromLA
Jul 19, 2006 03:35 PM
clanger
Mar 27, 2006 02:59 PM
