HELP! Where is the ABS Sensor ?
Old Nov 28, 2006 | 09:26 PM
FOXCONN4's Avatar
Default HELP! Where is the ABS Sensor ?
Hit a curb today trying to avoid an accident and bend the control arm. Now the ABS light is always on. I have repaired everything (Control Arm, Inner Tie Rod, and swaybar end liks). Need to turn off the ABS lights
Old Nov 29, 2006 | 05:48 AM
slalom44's Avatar
Top Answer: 1
The ABS Sensor is located on the back side of the wheel hub. It's near the center of the hub. You will see it if you look there.
Old Nov 29, 2006 | 08:38 AM
Boofster's Avatar
I think it's 21/22.
Your axle also has the little notches on it that trigger the pulse modulation. Make sure they're not damaged.
Old Nov 29, 2006 | 07:57 PM
FOXCONN4's Avatar
Thanks!!!
ChrisPackit
Jan 11, 2019 12:52 PM
AP1Driver
Oct 3, 2013 05:05 PM
Mister Jew
Sep 22, 2012 05:46 PM
kMfromLA
Jul 19, 2006 03:35 PM
mocantec
Jan 31, 2002 04:12 AM
