ABS Disengagement
Old Nov 4, 2001 | 06:49 PM
MaDcOw MoO!'s Avatar
Default ABS Disengagement
Anyone know if there is a way to disengage the ABS on the S2000 without having to mess with ECU? For example, the NSX and Integra Type-R allows the driver to turn off the ABS simply by driving over 10 MPH for 10 sec. with the Handbrake on (one click - not fully engaged). Just wondering if anyone knows of a way to do the same for the S2000.
Thanks
Old Nov 4, 2001 | 07:13 PM
Mike Schuster's Avatar
According to the electrical diagram, handbrake trick won't work, there appears to be no connection between the handbrake and the ABS system control. Here is what I would try: Turn off the ignition and remove ABS Motor fuse #23 and maybe also the ABS Fail/Safe fuse #22 in the main under-hood fuse box. See page 238 in the owner's manual. Expect to see the ABS warning light lit on the dash - a reminder to reinstall the fuses.
Old Nov 5, 2001 | 05:21 AM
Thanks for the info. Everything should work out fine.
AndyPandyNI
Jan 23, 2017 08:31 AM
QuadraJet
Oct 17, 2009 03:00 PM
AROD
May 29, 2007 02:37 PM
Davies2k
Jul 22, 2003 07:02 PM
Porsche518
Dec 14, 2000 02:19 PM
