ABS does not work and ABS light never comes on
So after autocrossing the car for the first time this past weekend, I quickly found out my abs doesn't work. At all. Also, when first turning the car on, the ABS light never lights up for a couple seconds. I checked both 20a and 30a fuses and they are both good. I replaced the abs module(electronic part attached to main abs pump) and the light still doesn't come on. Other than the idea that a previous owner pulled the LED out of the dash, does anybody else have any ideas? Thanks!
That means you have two codes and since you stated the light is not on, you have a burnt out bulb too.
Replace the bulb first, to verify it is none working. Then replace both sensors. The system will self reset if all is fine.
Holeshot121
Sep 11, 2021 12:17 PM
if lookz kill
Nov 29, 2006 04:06 PM
