ABS Light is on
Old Jul 10, 2006 | 06:09 AM
dty3's Avatar
Default ABS Light is on
Hey guys
i just installed koni's on the S, and everything went as planned.
i had to go and change the height settinga on the front because it was just too low.
now my ABS light is on. can you guys give any advice on whats possibly causing this and/or suggestions? basically what am i looking for when i pull off the front wheel?
thanks
Old Jul 10, 2006 | 09:44 AM
C4SxM5's Avatar
might get more help in the UTH forum.
about your issue. check the wires and make sure something didnt go loose. i never seen it happen on a S but a friend of mine accidentally unplugged it on his VW and the same thing happened.
GL
Old Jul 10, 2006 | 03:54 PM
Slows2k's Avatar
Make sure you didn't break or pull the wiring to a wheel speed sensor. You'll need a code to determine the problem from there.
Old Jul 10, 2006 | 05:25 PM
dty3's Avatar
ok, i was able to look at today.
in the front driver side wheel well, i appartently stretched the wire going into the fender. would i just have to pull the liner and see if the connection is bad?? or does it connect somewhere else in the car?
thanks
d
Old Jul 10, 2006 | 05:27 PM
Slows2k's Avatar
You're probably going to need to replace driver front wheel speed sensor. The wiring to then doesn't like to be pulled/stretched or spliced. it connects under the hood, by the shock tower.
Old Jul 10, 2006 | 05:31 PM
dty3's Avatar
thanks for the advice. i was thinking the same thing. i was looking at the majestic web site for the part. can anyone confirm the part i am looking to buy is 204994 SENSOR ASSY., L. FR.
helloimsteve
May 16, 2013 04:29 PM
durtbikedude365
May 17, 2011 09:28 AM
srg23
Mar 26, 2009 10:35 PM
fast-or-move!
Dec 30, 2008 11:51 AM
intake
Aug 17, 2004 10:15 PM
