EPS Consistently Out
Old May 15, 2013 | 10:22 PM
helloimsteve's Avatar
Default EPS Consistently Out
Hey guys, just did a wire tuck and having an issue with EPS.
When the car is jacked, EPS light doesn't come on. When the car is on the floor, the EPS light doesn't come on till the wheel is jerked. When I shut the car off and start it again, no EPS light till the wheel is jerked.
When I jerk the wheel to trip the EPS light, I hear a click in the passenger fender where the EPS module and fusebox is. The fuse isn't blown.
Anyone have any ideas? Maybe a bad ground?
Old May 15, 2013 | 10:38 PM
Edit:
I've tried to clear the codes using the reset procedure, but I don't think I can clear them with current codes existing. If you can, I must not be able to find the neutral position of the wheel.
Was able to get 3/4 codes cleared. I'm stuck with code:
DTC: 32 A problem with the main current sensor offset
Sorry I'm such an electrical nub.
Thanks in advance!
Old May 16, 2013 | 07:34 AM
Bump?
Old May 16, 2013 | 07:47 AM
franky's Avatar
Did you have to cut and add an extra length to the wires? If so, did you solder or did you use connectors? If you used connectors, then maybe its loose or not fully intact.
Old May 16, 2013 | 04:29 PM
Resolved! Not sure if this was the problem, but I resoldered connections and changed the grounding location. One of the two fixed it.
Thanks for the reply!
Fmj03
Jul 17, 2017 03:13 AM
ATX2000
Sep 28, 2016 01:42 PM
pinoyk20
Jun 30, 2008 11:33 AM
dty3
Jul 10, 2006 05:31 PM
intake
Aug 17, 2004 10:15 PM
