ABS light
Old Feb 8, 2008 | 09:30 PM
AusS2000's Avatar
Default ABS light
What does the ABS light on the dash mean? I'm guessing ABS failure but in what way?
Old Feb 9, 2008 | 05:51 AM
Spec_Ops2087's Avatar
Means the ABS system is disabled due to some problem.
You can either drive ~20mph and see if the system resets itself, it that doesn't work you need to pull the code using the honda DTC tool or shorting out pins 9 and 14 on the OBDII port; once shorted your abs light should flash a code which will tell you the problem.
Old Feb 10, 2008 | 08:24 PM
AusS2000's Avatar
I'm pretty sure it is my ABS unit.
It got somewhat melted during a recent turbo tuning disaster. The side by the turbo was completely melted away exposing the electronics. Worked for a while though.
I have a replacement I've been meaning to fit for a while.
Holeshot121
Sep 11, 2021 12:17 PM
Artric
Aug 19, 2016 01:18 AM
bgioan
May 15, 2014 06:40 PM
AndrewMcG
Mar 22, 2014 07:08 PM
if lookz kill
Nov 29, 2006 04:06 PM
