ABS LIGHT
Old Jun 23, 2009 | 01:34 PM
chikin tities's Avatar
Default ABS LIGHT
how do i check the abs light on my 02 s?
Old Jun 23, 2009 | 06:39 PM
negcamber's Avatar
You need to get the code read. It will tell you which sensor is having an issue.
Did you do any suspension work recently or brakes? It is easy to damage the sensor wire when doing that kind of work.
Old Jun 24, 2009 | 08:52 AM
s2k dre's Avatar
Only honda dealer has that scaner!
Old Jul 8, 2009 | 02:22 PM
really? no other way to check it?
Old Jul 11, 2009 | 12:14 PM
pimperthanu's Avatar
there is a way to get the code with just a piece of wire. its just like the procedure for reseting the abs light but do not press the brake. the abs light will blink the code which can be found in the service manual which you can get for free for ap1 at hondahookup.com. long blinks are 10 and short blinks are 1 and you just add it all up. it blinks the long ones first and then short and it pauses and repeats the code. this saved me TONS of money. I had a short in my abs sensor wire and just the diagnostics would have cost $95
FromaDB2toanAP1
May 9, 2015 12:02 AM
sp00led
Jul 25, 2011 03:43 AM
s2konroids
Jun 11, 2011 02:52 PM
Asura
Aug 2, 2007 08:17 PM
ImportSport
Apr 7, 2004 11:12 AM
